Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Kenmore Elite HE3 es una secadora eléctrica con una capacidad de 7.2 pies cúbicos de Kenmore.
Dryer won't start Error Code F70
Just had a Thunderstorm and lightning hit very close to our house blew 2 circuit breakers. I reset them and everything came on in the affected rooms. When my wife tried to start the dryer it wouldn't start and has an error code of F70 flashing. What does this mean and wan I fix it or do I need a technician?
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
1 Respuesta
Solución Elegida
Doug, F70 means check harness connections at the machine control and at the console electronics. If your connections are fine to the machine control board and the console electronics, then you may need to change the machine control board. Unplug your dryer first and leave it unplugged for a while to see if it resets It is below the top panel on the left hand side of the dryer panel. I attached the tech sheet for the dryer to the bottom of this page. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 6
3 comentarios:
I replaced a circuit board run as described "https://www.youtube.com/watch?v=eWqrn5kl...: However, I did not properly seat one of the plugs. I reopened dryerthe board and checked the plugs. Once I found the loose plug, I re-seated it properly and the dryer came up perfectly.
Thank you so much for this excellent video.
- de
Thanks to this information above I was able to get mine going too!!!! (Thank you)
- de
coding F01 is iqual a F70?
- de
Añadir tu respuesta
Doug estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 35,982
