Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
booting from usb external drive
Trying to fix my old PowerBook G4. I found my internal hard drive is dead.
I'm trying to reinstall the Mac OS-X but doesn't find any drives.
I attached an external USB drive (to try to install the software there) but doesn't find it. When I open disk repair, the external drive is there (the internal drive doesn't show)...
Any suggestions? Can I install the operating system in the external USB and boot from there?
Thanks!
David
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
1 comentario
Can you give us the OS-X version you are trying to install.
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Sadly you'll need a FireWire HD which has the older OS's this system uses, either OS-9 or OS-X 10.5.8.
Your other option is to boot off of the grey OS installer disks that came with the system or a retail copy of either of the OS's I've listed here.
Fue útil esta respuesta?
Puntuación 2
If your internal drive is dead it likely needs replacing. Have you done that yet?
Sadly, you can't boot up the older PowerPC based systems (G series) under a USB drive, you need to use a FireWire connected drive and the drive needs to have a bootable OS on it for your system.
Depending on the OS version you are working with here you may need an older version or use a boot disk that was created on a G series system as the earlier versions of OS-X had two installs one for PowerPC based systems and the other for Intel based systems.
Puntuación 1
Google told me, if any, it can only boot via a firewire harddrive, because it is a notebook before intel or sth like that. Just google it
Puntuación 0
Just put your new disk into the g4 and make a normal install it from your macosx dvd...
Pd.- if you cant give us more specific details we cant give you more specific solutions
Puntuación 0
Añadir tu respuesta
david estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,794
