MacBook Pro logic board component replace?
Hey guys, I've got a question about some component on my logic board of my 13" macbook pro (mid-2010) model (1278)
I'm repairing some liquid damage on this laptop with succes so far. I've cleaned the whole logic board with isopropyl alcohol, but unfortunately the (new) battery won't charge when plugged in the power source (mac does boot) I think it might be the mac-safe board but I also noticed a lose component..I think the part in the picture below isn't connection properly? (3 of 4 pins are loose) What is the function of this? Can it be replaced?
[url=http://postimg.org/image/wikf9e6ph/full/][img]http://s10.postimg.org/liz7xsgah/macbook...[/img][/url]
Thanks in advance!
Alex
Es esta una buena pregunta?
3 comentarios
Thanks a lot Dan and oldturkey03!
I'm going to replace that piece with a brand new one! You got any instructions for doing such operation? Just solder it loose and replace it? Or is that piece also connected with the other side of the logic board? For the corrosion, should I continue with cleaning the board with Isopropyl alcohol? or is there a better solution or method for this?
Thanks in advance!
Alex
- de Alex
Alex - You may want to try a solution of water and baking soda (tablespoon to a quart of distilled water). Use a tooth brush and scrub lightly with the solution. Afterwards wash the area down with straight distilled water and then go over the area with a good quality of isopropyl alcohol to help pull the water out.
- de Dan
Alex, take a look on here regarding the soldering http://www.howardelectronics.com/chipqui.... Here is also a decent video https://www.youtube.com/watch?v=3NN7UGWY... about the soldering process. The MOSFET is only soldered on one side of the board. It is a surface mounted component versus a through-the-hole component. Follow Dan's advice about the cleaning.
- de oldturkey03
