Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Optical drive swap for SSD
I'd like to swap out the optical drive with a SSD in a caddy to my powerbook G4 12" aluminum. I can't seem to see if the standard, SATA to IDE caddy will fit before I dismantle the entire computer. Thanks for any information.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Your between a rock and a hard place here, sorry
Sadly, there is no frame available for your system. And the SSD will be too fast for your system causing other problems.
I also wouldn't do it as your OS (OS-9 or early version of OS-X for PowerPC systems) does not have the needed support of SSDs TRIM services so you'll wear out the SSD out prematurely.
I would focus on upping the memory if you can and if you can update the hard drive to a larger drive (if you have limited free space) to gain what you can with this system.
Otherwise its time to safe ones pennies for a newer system (even a used Intel based model).
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Joeblois estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 252
