Why does my car Vibrate when I accelerate?
when I put the car in drive and accelerate it starts to vibrate badly. after I pick up speed it seems to get better
Es esta una buena pregunta?
Check your fuel injectors, have them cleaned, that should help, also check the spark plugs are in good shape...
Fernando R. (2007 Focus owner)
Fue útil esta respuesta?
No. It's your motor mount. Focus motor mounts going bad is common. I thought my daughter's exhaust was just loud in her car....I then realized it was the motor mount, replaced it, and it took care of the problem. If you are a do-it-yourselfer, this was not a big deal when I did her 2006 Focus ZX3. The main thing to be aware of is type of motor mount you buy at the parts store. I bought the "insert" and reused the metal housing...which worked fine but is a bit of work to put the insert in and bend the metal tab. The insert costs about $50. If you buy the entire motor mount, which would be easier to replace (pull the old one out, put the new one in) the entire unit costs about $110 I think. YouTube has videos.
It could be your bearings.
i have a2007 ford focus 1.6 si hatchback and when i take off from start the car vibrates or shudders but once i engage into 2nd gear the car goes well thereafter, this only happens when i take off from 1 st gear. my mechanic told me it could be the flywheel.
My guess, which I will substantiate this week, is a worn inner or outer cv joint on the front axle. The driver's door mirror glass vibrates on mine, so I'll concentrate on the left side . Reman axle from NAPA inexpensive, so would replace the axle assembly.
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 83
Todo El Tiempo: 15,971
2 comentarios
I have the same issue with my focus except mine also vibrates under de-acceleration. It's not the fuel injectors of ur sparkplugs. The issue lies in the ballence of ur wheels to the car. IE: you just bought 4 new tires and rims, had the tired ballenced to the new rims, but the new rims and tires need to be aligned to ur car. A possible solution would be to have ur car realigned.
- de brentenbear
it's the engine mounts, there are weak and worn.
- de kwljal
