Sreen goes blank for 3-4 sec
My laptop works great except a occaally the screen goes a dark gray for 3-4 seconds, then comes back. Any ideas? Thanks.
Es esta una buena pregunta?
Graphics chip, OR it cold be cables shorting. There's "known issues" with the solder joints failing over time on these graphic chips. Shimming helps, reflowing the solder is a temporary cure. Damaged cables can be replaced.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,035
1 comentario
Plug it into an external display, does the problem persist?
- de originalmachead
