display is only white
when turning on the PowerBook, i only get a white screen. i can hook up an external monitor and seen everything. When the startup cycle finishes, the display dims a bit. Is the display toast?
Es esta una buena pregunta?
I am far more suspicious of the cable from the logic board to the LCD but it could be the LCD. The fact that you have a good picture on the external monitor would lead me to believe your logic board is good. Check out the cable carefully before replacing the LCD. Good luck Ralph
Reemplazo del ensamblaje de la pantalla de aluminio PowerBook G4 de 15" 1.67 GHz
[producto vinculado inexistente o deshabilitado: IF154-103]
Fue útil esta respuesta?
agreed
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 666
