Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2201 Ver todo
Can not power on after replacing power button
my iphone 4s was having problem with the power button, i have to press very hard to get it to work. i got a replacement power button flex cable and replace it. but after the replacement, the power button completely stop working. I swap back the old cable/button, its not working either. What could be causing this? thanks
  • it does power on after i plug in the cable to the computer.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
There are a couple of issues. A couple times I have looked at this issue it ended up being that one or both of the screws on the power button retaining bracket were not installed. Does the button make clear clicks when depressed? It shouldn't be hard.
Check your cables for folds, tears or rips. Check the port the cable plugs into for dust, debris, or broken solder points. Is this phone still recognized by iTunes?
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
cli168 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 87
