Saltar al contenido principal
Lanzado en junio de 2009 / 2.66, 2.8 o 3.06 GHz Procesador Core 2 Duo
Replace A1286 Mid 2009 Logic board with a mid 2010 one?
I've looked deep into this over the course of the past 2 months, and I've came to the conclusion that all of the connectors and components between the Mid 2009 C2D logic board and the Mid 2010 Core i7-620m logic boards are identical, except for the heat sink, bluetooth and wifi board, and isight/antenna cables. All of the screw holes line up (they are both a1286 model number) and both use a nvidia chipset, so it seems the screen would work correctly without any modifications or additional parts.
I'm just wondering, what would the killer be when buying a mid 2010 logic board (with a core i7), a new isight/antenna cable, and a new bluetooth/wifi board and upgrading my computer this way rather than buying a newer macbook pro.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hey did the upgrade work for you? Im thinking along the same lines when it comes to my macbook...
- de
Agregar un comentario
2 Respuestas
Solución Elegida
The top case is a bit different as well. The are screw holes for the subwoofer on the 2010 which the earlier model lacks, and the bluetooth antennae on the 2010 has a piece of metal that looks like it attaches to the frame (glued?). The older model has a thin black plastic material covering that area (which appears to be cut away on the newer one, but I couldn't find any info on removing it and didn't want to mess it up so I left it in place.
HTH someone.
Fue útil esta respuesta?
Puntuación 1
If the model number is the same, it should work. However, I would recommend getting a brand new one as it will be much better.
Puntuación 0
1 comentario:
Apple uses the same model numbers for very different systems. They cannot be used to determine compatibility except very generally.
- de
Añadir tu respuesta
Mason Bleily estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 2,019
