Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
PB G4 Aluminum 12" does not have PRAM Battery?
hi,
i have PowerBook G4 Aluminum 12" that does not work,
and i wonder its PRAM Battery was down.
so, I want to replace the PRAM Battery.
But i can't find a PRAM Battery in PowerBook G4 Aluminum 12".
why? PowerBook G4 Aluminum 12" doesn't have a PRAM Battery?
please help me.
thank you.
shige
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
6 Respuestas
Solución Elegida
Try resetting the PRAM through Open Firmware:
Boot Mac while simultaneously holding Command+Option+O+F
When at the command prompt type the following:
reset-nvram <Enter>
reset-all <Enter>
The Mac should now reboot into OSX with a reset PRAM.
Also the RAM slot on this machine tends to fail. I would remove the RAM and try rebooting.
The 12" machines do not have PRAM batteries Chris is correct on the 12" not having a battery. Here's Apple article on it: http://support.apple.com/kb/TA25911?view...
Fue útil esta respuesta?
Puntuación 5
These machines, just like G3 and G4 iBooks do not use PRAM batteries, they use power from the main battery and a capacitor on the logic board to maintain the clock.
Puntuación 3
5 comentarios:
any reason for the down vote?
- de
Just to confirm, They do not have a PRAM battery, just like the iBooks.
- de
You are correct---the G4 DVI has a pram battery as do the Aluminum 15" and 17" but not the 12". ralph
- de
Confusing Chris, if it has no battery, why would he look online for someone selling them? You might want to edit this one.
- de
hi,
Mr. Chris
oh, i didn't guess that don't have PRAM BATT.
My machine only have a capacitor on the logic board.
i understood. thank you.
i guess main BATT is down too, so doesn't work...
Sir mayer,
you say not Command+Option+P+R, but Command+Option+O+F.
Ok, i will try.
thank you so much, every one.
shige, tokyo.
Puntuación 0
1 comentario:
That will also work.
- de
hi,
Chris
I have PowerBook G4 Aluminum 12".. Problem is that, when i charged it fully and then i open bluetooth or playing DVD, sudenly the battery level become very low , showing 1% or 2% charge.
Puntuación 0
1 comentario:
Please start a new question.
- de
I have a similar issue.
Does the booting with command option P + R
not work to reset PRAM with this 12" powerbook ?
I had found that on Apple support pages.
thanks
David
Puntuación 0
I need help with my Macbook 13". Sorry to plug it but no one has responded and I'd really appreciate some insight. Thanks!
Upgrade motherboard feasible with later model A1181
Puntuación 0
Añadir tu respuesta
shige estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 7,394
