Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fecha de lanzamiento: 24 de enero de 2008; 8 MP, zoom óptico de 3x, sistema de estabilización de imagen óptica integrado y software de detección de rostros; Procesador de imagen DIGIC III.
Get the message, Lens error, restart camera
When I turn the camera on, I get the error message, Lens error, restart camera. Then camera shuts off.
Es esta una buena pregunta?
Puntuación 9
1 comentario
I also have this problem with my Cannon 10x optical zoom.
- de
Agregar un comentario
5 Respuestas
Solución Elegida
M A, this happens most often if the camera was either dropped with the lens extended, knocking it off the guides, or if exposed to dirt/debris that will bind the lens when the camera turns on. Check the space around the lens and see if the spacing is equal distance all the way around. Sometimes you can use a vacuum cleaner and apply vacuum suction on the lens while powering it on. this may remove some of the dirt/debris and free the mechanism. If none of that works, you may have to replace the lens. The guide for that is here. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 5
1 comentario:
I even bought a can of air in a can and sprayed it all around the lens area and the whole camera, with no luck!
- de
This place fixed mine: www.camerasandparts.com Service through them was wonderful - they only work on Canons though.
Puntuación 2
I have a Canon Ixus 130 with the same error message, lens error. Now it won't start. I dropped it in the river. Can I use this guide to open the lens?
Puntuación 0
I did the thing with the card that this guy suggested and it fixed my problem.
https://www.youtube.com/watch?v=ZaFjEGDM...
Puntuación 0
In my camera it's not showing pictures and when we are taking pic.. it's not showing pictures
Puntuación 0
Añadir tu respuesta
M A estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 46
Ultimos 30 días: 270
Todo El Tiempo: 29,393
