Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2201 Ver todo
Pregunta Cerrada
iPhone 4s and 4 screen compatibility
I have both an iPhone 4 and an iPhone 4S. the 4S has a shattered screen http://imgur.com/FQuML and the 4 has a good screen (both GSM)
Are these two compatible? can I replace the 4S screen with the iPhone 4 screen?
Thank you!!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Citronex, this has been previously discussed. Check this answer and you will find more if you search the Answer section. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
In conclusion, 4 display can be connected to 4s. I am using like this, now.
But you need some trick.
iPhone 4 display assembly can not bind to 4s frame directly because 4's display assembly binding legs location are not matched to the 4s's location. You can tear the white(or black) plastic frame of 4 display assembly. Binding legs are attached to this assembly's plastic frame. If then, you can connect 4 display to the 4s body.
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 4,387
