Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HTC Evo Shift 4G es un teléfono inteligente comercializado como el sucesor simultáneo del teléfono inteligente Android insignia de Sprint.
My touch screen doesn't always function.
My HTC Evo shift works only 1/3 of the time. The other time, the touchscreen either freezes up so I can't make choices or it will make decisions by itself, such as to open the menu and select an option. It also likes to open an options panel while I am texting someone and call them instead.
It is out of my control! I brought it in to Sprint and they said I could replace the screen for $35, but I'm not sure the screen is the problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Well Miss Stabenow, the LCD may not be the problem, but the digitizer,(The part that give your phone its touch screen capabilities) may be the problem. That's why Sprint wanted to replace it. First try to give your phone a hard reboot. If that doesn't work, then you may want to get your digitizer replaced. But tell sprint you only want the DIGITIZER replaced only, not the whole display assembly. Hope I helped and happy repairing.
MacManiac
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Kimberly Stabenow estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 2,229
