Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El APC RS 1000 es una fuente de alimentación ininterrumpida capaz de entregar 600 Watts.
Overload alarm lights and sound
My ups, after 5 years of continuous operation shows the overload's light .
I unplugged the PC and I replaced the battery but I have not solved the problem.
Then I opened it to see if there are components that are burned or leak but nothing.
To be sure I replaced the cooling fan but nothing has changed.
Can anyone give me some tips?
Thank you very much.
Es esta una buena pregunta?
Puntuación 5
1 comentario
Hi, i had the same problem twice...!!!
My battery was ok, everything was ok but
the beep keep going on, for overload...
Both times i fixed doing these steps...
- Turn off the unit
- Flip over the unit
- Open the battery-cap and turn the power on
- Green Light is flashing
- Try Now (with the green light flashing) to disconnect the battery...
- Now it should be ON with the Empty battery light on (Red light)
- Connect again the battery as it is...
Now it should be ok...!!!
Good Luck...
- de Compartir
Agregar un comentario
5 Respuestas
Solución Elegida
Thanks to all. I have not solved the problem. I replaced the old ups with a new one.
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
Roberto, If it alarms, even with nothing plugged in, then it is possible that one of the MOSFET on your mainboard has failed.
Puntuación 4
3 comentarios:
metal–oxide–semiconductor field-effect transistor (MOSFET)
http://en.wikipedia.org/wiki/MOSFET
- de Compartir
Did you solve the problem? Same problem here, 4 years later..
daigoph@gmail.com
- de Compartir
Green light not so always yellow light and 5 Second deep alarm
- de Compartir
- Turn off the unit
Good Luck...
Puntuación 2
1 comentario:
Thank you but I replaced the old ups with a new one. Yours sincerely.
- de Compartir
I too facing the same problem....battery charging process is fine...but when i turn on the inverter it trips and shows overload and keep continuosly beep beeps....pls help me to solve this problem....i expecting board level service suggestions ...thank you
Puntuación 1
My problem solved with removing the all cables also power cable wait 5 minute & connect cable again it's working.
Puntuación 0
Añadir tu respuesta
Roberto estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 67
Todo El Tiempo: 39,603
