Saltar al contenido principal
Can I upgrade to more than 1g of ram
I have a 12" power book g4 with a 1.5 processor and 1g of ram and wanted to know if i can put a 2 gig stick in it....the problem is that im running leaoprd and it lagging when i run any application almost...im using it for serato djing program
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
According to Mactracker (if I have the right model for you) the maximum memory for your unit is 1.25 Ghz. That would be the built in 254M plus the 1G in the socket. It would help if you could confirm exactly which model you have. Check under the battery or use about this Mac to confirm. Ralph
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
agreed +
- de
it has 1.25 gigs in it i wanna know can i put a 2 gig stick in it and will it recognize it and run because im getting a system lag with the ram i have
- de
Model Name: PowerBook G4 12"
Model Identifier: PowerBook6,8
Processor Name: PowerPC G4 (1.5)
Processor Speed: 1.5 GHz
Number Of CPUs: 1
L2 Cache (per CPU): 512 KB
Memory: 1.25 GB
Bus Speed: 167 MHz
Boot ROM Version: 4.9.0f0
Serial Number (system): 4H548181RJ7
Hardware UUID: 00000000-0000-1000-8000-001124471C1C
Sudden Motion Sensor:
State: Enabled
Version: 1.0
- de
According to Mactracker and my personal experience you have the maximum memory your computer will recognize. Ralph
- de
Here is a URL showing the max ram for the various Mac models. Ralph
http://www.everymac.com/systems/by_capab...
- de
you can add 2gb ram if you find a 200pin single 2gb stick that is ddr1 sodimmm pc2700 or above. you cannot add the easier to find 184pin versions and you cant add pc2100 ram sticks. you can also not add the more common ddr2 2gb sticks.
i will do it myself in the near future cause i heard of few people who did it and it worked.
if you find a pc3200 ddr1 sodimm 2gb stick 200pin version, that wil work too cause it automatically downscales to pc2700 speed
good luck in finding a suited 2gb stick, i am on the search also:)
Puntuación 0
1 comentario:
Please let us know if it works. I won't recommend a procedure that hasn't been proved because it cost the questioner money.
- de
Hallo!
I will get a 2gb ram sodimm 200pin pc3200. I hope it arrives in the next weeks. I will try it as soon as i have it in my 12" g4 1,5ghz powerbook and will let you know if it worked or not.
It is a risk for me, cause if it doesnt work i lost some money.
I called apple and went into shops and no one can really tell me if it will work or not.
The problem is it is a ECC ram. ECC ram is only officially supported in G5 ppc macs. The onboard ram in a g4 powerbook is non ECC.
When researching the net i read different opinions, it may work, or it may not work. Some mainboards, though officially not supporting ecc just bring it to work in not using the ecc. Others dont work at all with it, and again others can be made to work with ecc by disabling ecc in the bios.
I dont know how to get into a g4 powerbooks bios. Apple doesnt even have a bios i think. Theres sth like a bios but i dont remember how its called or how you work in it.
I am thankful for any more information regarding that matter!
Puntuación 0
Añadir tu respuesta
BIG REDD estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 3,301
