Saltar al contenido principal
Versión CDMA del iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben reemplazarse como una unidad. Compatibilidad de 16 o 32 GB / Modelo A1349 / CDMA.
Preguntas 295 Ver todo
iPhone screen is black but phone is working
My iphone 4 screen has gone black, but the phone is still working. I had the screen replaced last spring and it's been working fine since then. Today it goes black but is still working. I have not dropped it or anything, I just can't see anything. Does anyone have any ideas what has happened and what can I do to fix it? Thanks.
Es esta una buena pregunta?
Puntuación 2
1 comentario
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Melissa, before trying to purchase a new LCD, try to reset your phone. Hold the sleep/wake button at the top right and the home button at the same time. Keep holding until the screen go black. Sometime you have to keep holding even after the red power off slider appears. If it does, just keep holding it. Once the Apple logo appears let go of the buttons, your phone should now reboot. Always make sure that you back up your phone promptly so as to minimize any loss of important data. After you back it up you could also try a restore. If that does not accomplish anything, it may be time to disassemble your phone, check all the connectors, and then consider a new LCD.Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
it just worked for me woooohoooo
- de
Thank you it just worked for me too after me googling this for the same problem!!
- de
Añadir tu respuesta
Melissa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 7,778
