Introducción
The shiny rear half of your iPod case.
Partes
No se requieren partes.
Before opening your iPod, ensure that the hold switch is in the locked position.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
Agregar Comentario
Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Agregar Comentario
Continue to run the opening tool along the side of the case until all five tabs have been released.
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
Agregar Comentario
Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
Agregar Comentario
Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
Agregar Comentario
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
  • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 7
Todo El Tiempo: 5,687
