Saltar al contenido principal
Motorola Moto X4 Fingerprint Sensor Replacement
Qué necesitas
  1. Motorola Moto X4 Fingerprint Sensor Replacement, Heat the screen: paso 1, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement, Heat the screen: paso 1, imagen 2 de 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
  2. Motorola Moto X4 Fingerprint Sensor Replacement, Create a gap: paso 2, imagen 1 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Create a gap: paso 2, imagen 2 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Create a gap: paso 2, imagen 3 de 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
  3. Motorola Moto X4 Fingerprint Sensor Replacement, Slice the screen adhesive: paso 3, imagen 1 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Slice the screen adhesive: paso 3, imagen 2 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Slice the screen adhesive: paso 3, imagen 3 de 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Motorola Moto X4 Fingerprint Sensor Replacement: paso 4, imagen 1 de 3 Motorola Moto X4 Fingerprint Sensor Replacement: paso 4, imagen 2 de 3 Motorola Moto X4 Fingerprint Sensor Replacement: paso 4, imagen 3 de 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  5. Motorola Moto X4 Fingerprint Sensor Replacement: paso 5, imagen 1 de 3 Motorola Moto X4 Fingerprint Sensor Replacement: paso 5, imagen 2 de 3 Motorola Moto X4 Fingerprint Sensor Replacement: paso 5, imagen 3 de 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  6. Motorola Moto X4 Fingerprint Sensor Replacement: paso 6, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement: paso 6, imagen 2 de 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  7. Motorola Moto X4 Fingerprint Sensor Replacement: paso 7, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement: paso 7, imagen 2 de 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  8. Motorola Moto X4 Fingerprint Sensor Replacement: paso 8, imagen 1 de 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Motorola Moto X4 Fingerprint Sensor Replacement, Detach the fingerprint sensor cable: paso 9, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement, Detach the fingerprint sensor cable: paso 9, imagen 2 de 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  10. Motorola Moto X4 Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 10, imagen 1 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 10, imagen 2 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 10, imagen 3 de 3
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  11. Motorola Moto X4 Fingerprint Sensor Replacement, Disconnect the display cable: paso 11, imagen 1 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Disconnect the display cable: paso 11, imagen 2 de 3 Motorola Moto X4 Fingerprint Sensor Replacement, Disconnect the display cable: paso 11, imagen 3 de 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  12. Motorola Moto X4 Fingerprint Sensor Replacement, Remove the screen: paso 12, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement, Remove the screen: paso 12, imagen 2 de 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
  13. Motorola Moto X4 Fingerprint Sensor Replacement, Heat the fingerprint sensor: paso 13, imagen 1 de 1
    • Apply a heated iOpener to the fingerprint sensor for one minute to soften the adhesive gasket.
  14. Motorola Moto X4 Fingerprint Sensor Replacement, Loosen the fingerprint sensor: paso 14, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement, Loosen the fingerprint sensor: paso 14, imagen 2 de 2
    • Slide the point of a spudger under the fingerprint sensor cable and gently pry to loosen the cable from the screen.
  15. Motorola Moto X4 Fingerprint Sensor Replacement: paso 15, imagen 1 de 2 Motorola Moto X4 Fingerprint Sensor Replacement: paso 15, imagen 2 de 2
    • Use an opening tool to pry up and loosen the fingerprint sensor from the screen.
  16. Motorola Moto X4 Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 16, imagen 1 de 1
    • Remove the fingerprint sensor.
    • To reattach the fingerprint sensor, use a precut gasket, or apply some thin strips of Tesa adhesive to the perimeter of the sensor.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
Arthur Shi
Miembro Desde 01/03/18
253,457 Reputación
526 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,198 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 729
