Saltar al contenido principal
Microsoft Surface Laptop 3 13.5" Feet Replacement
Qué necesitas
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: paso 1, imagen 1 de 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: paso 1, imagen 2 de 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: paso 2, imagen 1 de 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: paso 2, imagen 2 de 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: paso 3, imagen 1 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: paso 3, imagen 2 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: paso 3, imagen 3 de 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: paso 4, imagen 1 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: paso 4, imagen 2 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: paso 4, imagen 3 de 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: paso 5, imagen 1 de 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: paso 5, imagen 2 de 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: paso 6, imagen 1 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: paso 6, imagen 2 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: paso 6, imagen 3 de 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Una persona más ha completado esta guía.
Carsten Frauenheim
Miembro Desde 03/10/20
114,572 Reputación
339 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
Un comentario
Nice, that good for me, first time :D
TrungLun0112 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 29
Ultimos 30 días: 170
Todo El Tiempo: 5,769
