Saltar al contenido principal
MacBook Pro 15" Retina Display Early 2013 SSD Replacement
Qué necesitas
  1. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: paso 2, imagen 1 de 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Battery Connector: paso 3, imagen 1 de 1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: paso 4, imagen 1 de 2 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: paso 4, imagen 2 de 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, SSD: paso 5, imagen 1 de 1
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  6. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: paso 6, imagen 1 de 2 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: paso 6, imagen 2 de 2
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
Conclusión
59 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,854 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,198 Guías creadas
17 comentarios
Where is the left fan in the pic? Please tell me I don't need to remove the fan before doing the replacement.
Ethan - Contestar
I see that for all the guides for all the MBP models with solid state storage, the battery is disconnected before the solid state storage is removed. Why?
Traditional hard drives and SSDs don't have to have their batteries disconnected before removing...do they?
Hobowan Kenobi - Contestar
You should remove it. It's just good practice when doing anything internal on any laptop.
farleyaustin -
这个ssd的接口是什么呢?我应该购买什么型号的ssd能适配这个,怎么筛选?
lizhao - Contestar
Can I update my SSD to 1TB from 512GB? RMBP 2013 Early
FAN Guoxing - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 72
Ultimos 30 días: 245
Todo El Tiempo: 101,704
