Saltar al contenido principal
MacBook Air 2022 (M2) Left Speaker Replacement
Qué necesitas
  1. MacBook Air 2022 (M2) Left Speaker Replacement, Prepare your Macbook Air for disassembly: paso 1, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Prepare your Macbook Air for disassembly: paso 1, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Prepare your Macbook Air for disassembly: paso 1, imagen 3 de 3
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the lower case: paso 2, imagen 1 de 2 MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the lower case: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    FixMat
    $36.95
    Comprar
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Left Speaker Replacement, Insert an opening pick: paso 3, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Insert an opening pick: paso 3, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Insert an opening pick: paso 3, imagen 3 de 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Left Speaker Replacement, Release the snapping clips: paso 4, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the snapping clips: paso 4, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the snapping clips: paso 4, imagen 3 de 3
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 2022 (M2) Left Speaker Replacement: paso 5, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement: paso 5, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement: paso 5, imagen 3 de 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 2022 (M2) Left Speaker Replacement, Release the sliding tabs: paso 6, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the sliding tabs: paso 6, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the sliding tabs: paso 6, imagen 3 de 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the lower case: paso 7, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the lower case: paso 7, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the lower case: paso 7, imagen 3 de 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the battery connector cover: paso 8, imagen 1 de 1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
    • Due to screw variances, you may need to use a T4 Torx instead. Keep this in mind whenever you encounter T3 Torx screws during this repair.
  9. MacBook Air 2022 (M2) Left Speaker Replacement: paso 9, imagen 1 de 2 MacBook Air 2022 (M2) Left Speaker Replacement: paso 9, imagen 2 de 2
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the battery: paso 10, imagen 1 de 2 MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the battery: paso 10, imagen 2 de 2
    • Use an opening pick to pry up and disconnect the battery connector.
  11. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the speaker cable covers: paso 11, imagen 1 de 1
    • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
    • Use a T3 Torx driver to remove the four 1.5 mm screws securing the left speaker cable covers.
  12. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker cable covers: paso 12, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker cable covers: paso 12, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker cable covers: paso 12, imagen 3 de 3
    • Remove the two speaker cable covers.
  13. MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the speaker cables: paso 13, imagen 1 de 2 MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the speaker cables: paso 13, imagen 2 de 2
    • Use the pointed end of a spudger to pry up and disconnect the left speaker press connector.
  14. MacBook Air 2022 (M2) Left Speaker Replacement: paso 14, imagen 1 de 2 MacBook Air 2022 (M2) Left Speaker Replacement: paso 14, imagen 2 de 2
    Comprar
    • Use a pair of tweezers to grip the right antenna connector, as close to its base as possible.
    • Lift straight up to disconnect the cable.
    • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
    • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  15. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the right hinge cover: paso 15, imagen 1 de 1
    • Use a T3 Torx driver to remove the 2.6 mm screw securing the right hinge cover.
  16. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the right hinge cover: paso 16, imagen 1 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the right hinge cover: paso 16, imagen 2 de 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the right hinge cover: paso 16, imagen 3 de 3
    • Grip the right hinge cover with blunt nose tweezers.
    • Pull the cover toward the bottom of the laptop and upward to free it from its recess.
    • Pull up and remove the hinge cover.
  17. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the speaker: paso 17, imagen 1 de 1
    • Use a T5 Torx driver to remove the three screws securing the left speaker:
    • Two 5.6 mm screws
    • One 3.5 mm screw
  18. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker: paso 18, imagen 1 de 2 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker: paso 18, imagen 2 de 2
    • Lift the left speaker straight up and remove it.
Conclusión
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Spencer Day
Miembro Desde 09/14/22
55,243 Reputación
408 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,449 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 34
Ultimos 30 días: 114
Todo El Tiempo: 1,365
