Introducción
This step-by-step repair guide demonstrates a battery replacement for the Lenovo Yoga 900-13ISK. The battery supplies power to the computer while it is unplugged, allowing it to function as a mobile device. However, lithium ion batteries have a limited lifespan, and will start to lose the ability to hold a charge over time. If you notice that your Lenovo Yoga 900 is losing its ability to hold a charge, replacing the battery can restore the functionality of your device.
Batteries, even old ones, are toxic and cannot be thrown away in your normal waste bin. Please find a suitable e-waste recycler near you to properly dispose of your old battery.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If the battery within your device is swollen, take appropriate precautions.
Be sure to unplug and completely turn off your device before you start working.
Qué necesitas
Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
