Saltar al contenido principal
Lenovo ThinkPad T480s Fan Assembly Replacement
Qué necesitas
  1. Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Fan Assembly Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T480s Fan Assembly Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T480s Fan Assembly Replacement: paso 2, imagen 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Fan Assembly Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T480s Fan Assembly Replacement: paso 3, imagen 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: paso 4, imagen 1 de 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: paso 4, imagen 2 de 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s Fan Assembly Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad T480s Fan Assembly Replacement: paso 5, imagen 2 de 2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  6. Lenovo ThinkPad T480s Fan Assembly Replacement: paso 6, imagen 1 de 3 Lenovo ThinkPad T480s Fan Assembly Replacement: paso 6, imagen 2 de 3 Lenovo ThinkPad T480s Fan Assembly Replacement: paso 6, imagen 3 de 3
    • Lift the thermal fan assembly from the system and remove it.
Conclusión
2 personas más completaron esta guía.
Sarah Westberg
Miembro Desde 03/11/19
23,294 Reputación
70 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,309 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 83
Todo El Tiempo: 3,153
