Introducción
A step-by-step guide to replacing the screen of the Garmin Nuvi 680.
Flip open the antenna on the back of the device.
  • Flip open the antenna on the back of the device.
  • Remove the two screws on the antenna cover using a T5 Torx screwdriver.
    • These screws are 4.42 mm long.
Agregar Comentario
Remove the antenna cover.
  • Remove the antenna cover.
Agregar Comentario
The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
  • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
  • Pull the antenna circuit board out of its case.
Agregar Comentario
Insert the pointed end of a spudger into the leftmost slit of the antenna case. Push the spudger to the right.
  • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
  • Push the spudger to the right.
  • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
  • Slide the antenna case out of the device.
  • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
Agregar Comentario
Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
  • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
Agregar Comentario
Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables. Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
  • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
Agregar Comentario
Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard. Remove the antenna.
  • Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard.
  • Remove the antenna.
The antenna ribbon cable has a latch that must be lifted first. It's a light muddy brown color. It flips up and away in the opposite direction of the ribbon cable.
ewkpates - Contestar
Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
  • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
  • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
  • Gently pull the ribbon cables out of their connectors. They should slide out easily.
  • Do not separate the two halves of the device yet or the on/off cable may be severed.
Agregar Comentario
Gently pull the cable for the on/off button straight up to remove it. The two halves of the device may now be separated.
  • Gently pull the cable for the on/off button straight up to remove it.
  • The two halves of the device may now be separated.
Agregar Comentario
Push the tabs towards the outside of the case, the tabs are located as shown. Push the screen out of the case after the tabs are loosened.
  • Push the tabs towards the outside of the case, the tabs are located as shown.
  • Push the screen out of the case after the tabs are loosened.
  • Slide the screen out of the cover.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Chris Marzano
Miembro Desde 20/01/11
968 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-22, Amido Winter 2011 Miembro de Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Miembros
7 Guías creadas
Great instructions, thank you
I was able to fix my GPS which I thought was headed for the recyclers.
Saved me from purchasing a replacement.
knockout - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 10,059
