Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
  • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
  • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
  • Gently pull the ribbon cables out of their connectors. They should slide out easily.
  • Do not separate the two halves of the device yet or the on/off cable may be severed.
Insertar traducción aquí
