Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 4
Insert the pointed end of a spudger into the leftmost slit of the antenna case. Push the spudger to the right.
  • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
  • Push the spudger to the right.
  • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
  • Slide the antenna case out of the device.
  • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
Insertar traducción aquí
