Saltar al contenido principal
Clothing Ribbon Button Replacement
Qué necesitas
  1. Clothing Ribbon Button Replacement, Ribbon Button: paso 1, imagen 1 de 2 Clothing Ribbon Button Replacement, Ribbon Button: paso 1, imagen 2 de 2
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: paso 2, imagen 1 de 2 Clothing Ribbon Button Replacement: paso 2, imagen 2 de 2
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: paso 3, imagen 1 de 3 Clothing Ribbon Button Replacement: paso 3, imagen 2 de 3 Clothing Ribbon Button Replacement: paso 3, imagen 3 de 3
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: paso 4, imagen 1 de 3 Clothing Ribbon Button Replacement: paso 4, imagen 2 de 3 Clothing Ribbon Button Replacement: paso 4, imagen 3 de 3
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: paso 5, imagen 1 de 3 Clothing Ribbon Button Replacement: paso 5, imagen 2 de 3 Clothing Ribbon Button Replacement: paso 5, imagen 3 de 3
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: paso 6, imagen 1 de 3 Clothing Ribbon Button Replacement: paso 6, imagen 2 de 3 Clothing Ribbon Button Replacement: paso 6, imagen 3 de 3
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: paso 7, imagen 1 de 2 Clothing Ribbon Button Replacement: paso 7, imagen 2 de 2
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: paso 8, imagen 1 de 3 Clothing Ribbon Button Replacement: paso 8, imagen 2 de 3 Clothing Ribbon Button Replacement: paso 8, imagen 3 de 3
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: paso 9, imagen 1 de 2 Clothing Ribbon Button Replacement: paso 9, imagen 2 de 2
    • Clip any threads.
    • Admire your handiwork.
Linea de Meta
Una persona más ha completado esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
89,017 Reputación
131 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 2,800
