Saltar al contenido principal
JBL Charge 3 Battery Upgrade
Inglés
Holandés
Paso 5
JBL Charge 3 Battery Upgrade, Replacing the battery (OPTION B): paso 0, imagen 1 de 3 JBL Charge 3 Battery Upgrade, Replacing the battery (OPTION B): paso 0, imagen 2 de 3 JBL Charge 3 Battery Upgrade, Replacing the battery (OPTION B): paso 0, imagen 3 de 3
  • You need to wire them in Parallel (i.e. 1s3p pack).
  • Two unprotect will be wired to the JBL BMS board. I solder the black wire to the B+ and the red wire to the B-.
  • To keep the next replacement easier, I only connect the battery by twisting the color coded wires together and wrapping them with electrical tape.
  • One unprotected cell will be in the original battery compartment inside the cell holder (as shown) connect to one side of the BMS board.
  • Two cells will be inside the speaker compartment behind the Bass Radiator. The unprotected one (right hand side radiator) will connect directly to the BMS board.
  • The protected one (after I open and rearrange the PCB of the battery for a better fit into the speaker compartment) will connect parallel to the protected one from other side of the bass radiator.
Insertar traducción aquí
