Saltar al contenido principal
Reemplazo de batería de Google pixel
Inglés
Español
Paso 4
Google Pixel Battery Replacement: paso 0, imagen 1 de 2 Google Pixel Battery Replacement: paso 0, imagen 2 de 2
  • The battery has a jacket that can double as a battery removal tab, pull it to remove the battery. If that doesn't work, follow the instructions below.
  • Carefully wedge an opening pick underneath the battery to break the adhesive.
  • If the battery does not come out easily, don't pry aggressively. Apply heat to the back of the phone with an iOpener or a heat gun to loosen the adhesive.
  • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
Acuna un spudger debajo de la batería para quitarlo del dispositivo.
Haz todo lo posible para no deformar la batería durante este proceso. Las baterías de iones de litio de cubierta blanda pueden derramar sustancias químicas peligrosas, incendiarse o incluso explotar si están dañadas. No uses fuerza excesiva ni hagas palanca en la batería con herramientas metálicas.
