Saltar al contenido principal
Canon PowerShot G1 X Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 2
Paso 2
Canon PowerShot G1 X Battery Replacement: paso 0, imagen 1 de 2 Canon PowerShot G1 X Battery Replacement: paso 0, imagen 2 de 2
  • To release the battery, gently push the switch off the top of the battery and pull the battery out of the casing.
  • Place the new battery in the casing with the four metal connections (small squares on the bottom of the battery)in the bottom right hand corner of the bottom of the camera. If you look inside the casing you will see where the connections will meet. This will give you more of an idea on the orientation of the battery.
Insertar traducción aquí
