Saltar al contenido principal
Canon PowerShot SD1200 IS Flash Assembly Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Canon PowerShot SD1200 IS Flash Assembly Replacement: paso 0, imagen 1 de 3 Canon PowerShot SD1200 IS Flash Assembly Replacement: paso 0, imagen 2 de 3 Canon PowerShot SD1200 IS Flash Assembly Replacement: paso 0, imagen 3 de 3
  • Use the spudger to pry up each side of the lens assembly Flat-Topped Connector at the bottom of the motherboard.
  • Holding back the lens assembly ribbon cable, use the spudger to lift the Zero Insertion Force (ZIF) connector tab . Slide out the ribbon cable.
  • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  • Use the spudger to lift the Zero Insertion Force (ZIF) connector tab located on the flash unit. Remove the ribbon cable.
Insertar traducción aquí
