Introducción
Use this guide to access or replace the flash assembly on your Canon Powershot SD1200 IS camera.
Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
Slide out the ribbon cable using fingers or tweezers.
Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
Use the spudger to pry up each side of the lens assembly Flat-Topped Connector at the bottom of the motherboard.
Holding back the lens assembly ribbon cable, use the spudger to lift the Zero Insertion Force (ZIF) connector tab . Slide out the ribbon cable.
Use the spudger to lift the Zero Insertion Force (ZIF) connector tab located on the flash unit. Remove the ribbon cable.
