Saltar al contenido principal
Canon PowerShot SD1200 IS Motherboard
Inglés
Holandés
Paso 3
Canon PowerShot SD1200 IS Motherboard: paso 0, imagen 1 de 2 Canon PowerShot SD1200 IS Motherboard: paso 0, imagen 2 de 2
  • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
  • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  • Slide out the ribbon cable.
  • Use the spudger to pry up each side of the Flat-Topped Connectors
Insertar traducción aquí
