Saltar al contenido principal
Nikon Coolpix 995 LCD Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
Nikon Coolpix 995 LCD Replacement: paso 0, imagen 1 de 2 Nikon Coolpix 995 LCD Replacement: paso 0, imagen 2 de 2
  • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
  • Remove the two screws with a Phillips #00 screwdriver.
  • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
  • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
Insertar traducción aquí
