Saltar al contenido principal
Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement
Inglés
Holandés
Paso 2
Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement, Remove LCD Connector and Wi-Fi Cables: paso 0, imagen 1 de 3 Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement, Remove LCD Connector and Wi-Fi Cables: paso 0, imagen 2 de 3 Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement, Remove LCD Connector and Wi-Fi Cables: paso 0, imagen 3 de 3
  • Remove the LCD connector from the motherboard by pulling up on the black tap which is located on top of the connector. (See pic 1)
  • There are 2 wires that run from the LCD assembly to the Wi-Fi card. There is a black and white wire. Using a spudgeryou can carefully navigate under both gold tips of the black and white wires and then lightly pry them off in an upwards motion.
  • Unwind/remove the black and white wires from their original black clip path which are secured around the fan. There are also 1 metal clip attached to the bottom of the palmrest. (See pic 3)
Insertar traducción aquí
