Saltar al contenido principal
Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement, Remove LCD Hinge Screws: paso 0, imagen 1 de 3 Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement, Remove LCD Hinge Screws: paso 0, imagen 2 de 3 Dell Chromebook 11 CB1C13 LCD Hinged Assembly Replacement, Remove LCD Hinge Screws: paso 0, imagen 3 de 3
  • Remove the 3 hinge screws using a Phillips #0 screwdriver. The left hinge has 2 screws while the right hinge only has 1.
  • The left hinge has 2 screws that can be removed with a Phillips #0 screwdriver.
  • The right hinge only has 1 screw. You may need to pull the charging port up and out of the way so you can get a better view of the 1 hinge screw. (See 3rd pic)
Insertar traducción aquí
