Saltar al contenido principal
Sustitucion de la carcasa superior de MacBook Core 2 Duo
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 38 guías que incluyen este paso.
Inglés
Español
Paso 7
MacBook Core 2 Duo Upper Case Replacement: paso 0, imagen 1 de 1
  • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
  • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
  • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
  • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
  • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
Hay un cable plano del teclado y del trackpad que conecta la carcasa superior a la placa lógica, así que no saques la carcasa superior del todo todavía.
Utiliza una herramienta de apertura de plástico, un crédito de plástico caducado o una tarjeta de grosor similar para hacer palanca en la carcasa superior, comenzando en la esquina superior izquierda y trabajando alrededor de la parte frontal del ordenador.
Es probable que la carcasa superior se atasque en su conexión por encima del borde frontal de la unidad óptica. Si esto ocurre, libera primero todos los demás lados y, a continuación, tira hacia arriba de la carcasa superior desde cualquier lado de la abertura de la unidad óptica.
También en este caso puede ser útil introducir una tarjeta de plástico, una púa de guitarra, etc.
Si apoyas la base del MacBook sobre un extremo para ver mejor, es posible que desplaces los cuatro clips de plástico gris que sujetan el lado derecho de la carcasa superior. Que no cunda el pánico. Se deslizan en unas ranuras situadas en el borde superior derecho del marco inferior, encima del borde frontal de la unidad óptica.
Durante el montaje, asegúrate de que los clips del lado derecho, encima de la unidad óptica, encajan firmemente en su sitio. Son diferentes de los clips del lado izquierdo, por lo que normalmente requieren una presión un poco más firme para encajar en su sitio.
