Saltar al contenido principal
MacBook Core Duo Clutch Cover Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 19 guías que incluyen este paso.
Inglés
Español
Paso 2
MacBook Core Duo Clutch Cover Replacement: paso 0, imagen 1 de 1
  • While holding the display down with one hand, use your other hand to lift the left end of the clutch cover off the clutch hinge and guide the inverter cable and AirPort cables through the gap in the clutch cover. If the cables snag on the two hooked tabs on the inside end of the clutch cover, free them carefully.
  • It may help to wiggle the clutch cover as you pull it up from the display.
  • During reassembly, make sure not to pinch the black inverter cable or the Airport wires when snapping the left end of the clutch cover back into place. To avoid pinching, it may help to lift up and hold these cables and wires in place at the top of the hinge, rather than leaving them running along the sides of the hinge.
Insertar traducción aquí
