Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 19 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift the clutch cover out of the display assembly.
  • During reassembly, make sure not to pinch the backlight cable (with the white connector on the right side) when snapping the clutch cover back into place. This cable has two visible wires leading into the lower right section of the LCD display to the backlight. (The models with pink and white wires are usually longer and easier to pinch.)
Insertar traducción aquí
