Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 6
Insert an opening pick about 0.5 inches (~12mm) under the opposite bottom corner of the display. Keep a close eye on the button's ribbon cable as you insert the pick. The cable is fragile and very easy to tear. If the pick is hard to insert or the cable starts to stretch, apply more heat.
  • Insert an opening pick about 0.5 inches (~12mm) under the opposite bottom corner of the display.
  • Keep a close eye on the button's ribbon cable as you insert the pick. The cable is fragile and very easy to tear. If the pick is hard to insert or the cable starts to stretch, apply more heat.
  • Leave the pick under the display to prevent the button from re-adhering to the display.
Desliza la segunda púa hacía la segunda tarjeta lógica (donde se encuentra la entrada USB)
