Saltar al contenido principal
Canon PowerShot SX50 HS Rear Case Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 5
Canon PowerShot SX50 HS Rear Case Replacement: paso 0, imagen 1 de 3 Canon PowerShot SX50 HS Rear Case Replacement: paso 0, imagen 2 de 3 Canon PowerShot SX50 HS Rear Case Replacement: paso 0, imagen 3 de 3
  • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
  • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
  • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
Insertar traducción aquí
