Saltar al contenido principal
Canon PowerShot SX50 HS Rear Case Replacement
Qué necesitas
  1. Canon PowerShot SX50 HS Rear Case Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Rear Case Replacement: paso 2, imagen 1 de 1
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: paso 3, imagen 1 de 2 Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: paso 3, imagen 2 de 2
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  4. Canon PowerShot SX50 HS Rear Case Replacement: paso 4, imagen 1 de 2 Canon PowerShot SX50 HS Rear Case Replacement: paso 4, imagen 2 de 2
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  5. Canon PowerShot SX50 HS Rear Case Replacement: paso 5, imagen 1 de 1
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  6. Canon PowerShot SX50 HS Rear Case Replacement: paso 6, imagen 1 de 2 Canon PowerShot SX50 HS Rear Case Replacement: paso 6, imagen 2 de 2
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  7. Canon PowerShot SX50 HS Rear Case Replacement: paso 7, imagen 1 de 3 Canon PowerShot SX50 HS Rear Case Replacement: paso 7, imagen 2 de 3 Canon PowerShot SX50 HS Rear Case Replacement: paso 7, imagen 3 de 3
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  8. Canon PowerShot SX50 HS Rear Case Replacement: paso 8, imagen 1 de 3 Canon PowerShot SX50 HS Rear Case Replacement: paso 8, imagen 2 de 3 Canon PowerShot SX50 HS Rear Case Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
  9. Canon PowerShot SX50 HS Rear Case Replacement: paso 9, imagen 1 de 1
    • Now you can completely separate the back encasement from the rest of the camera.
Conclusión
3 personas más completaron esta guía.
Daniel Gurrola
Miembro Desde 04/01/15
267 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-7, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 14
Todo El Tiempo: 1,195
