Saltar al contenido principal
Canon PowerShot S100 Outer Case Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 3
Paso 3
Canon PowerShot S100 Outer Case Replacement: paso 0, imagen 1 de 3 Canon PowerShot S100 Outer Case Replacement: paso 0, imagen 2 de 3 Canon PowerShot S100 Outer Case Replacement: paso 0, imagen 3 de 3
  • Turn the camera so that the lens is facing you.
  • Do not pull the front panel off without removing the ribbon cable first.
  • Slowly lift the front panel from the camera.
  • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
  • A spudger may also be used to remove the ribbon cable.
  • Remove the rubber guard that rests on top of the lens.
Insertar traducción aquí
