Saltar al contenido principal
Canon PowerShot S100 Outer Case Replacement
Qué necesitas
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: paso 1, imagen 1 de 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: paso 1, imagen 2 de 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: paso 1, imagen 3 de 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: paso 2, imagen 1 de 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: paso 3, imagen 1 de 3 Canon PowerShot S100 Outer Case Replacement: paso 3, imagen 2 de 3 Canon PowerShot S100 Outer Case Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
Conclusión
Una persona más ha completado esta guía.
Ricky
Miembro Desde 02/23/15
968 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-4, Leahy Winter 2015 Miembro de USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 1,209
