Saltar al contenido principal
Canon PowerShot SD200 Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Canon PowerShot SD200 Battery Replacement: paso 0, imagen 1 de 3 Canon PowerShot SD200 Battery Replacement: paso 0, imagen 2 de 3 Canon PowerShot SD200 Battery Replacement: paso 0, imagen 3 de 3
  • The camera used to create these repair guides had a broken lens assembly. As a result, the lens is sticking out in all of the photos, but it is important to note that this should not be the case with your camera. The lens should retract itself back into the camera when it is turned off.
  • Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
  • Slide the light gray door away from the LCD screen and pull up to open the door.
  • Both battery and memory card should now be visible.
Insertar traducción aquí
