Saltar al contenido principal
Canon PowerShot SD200 Battery Replacement
  1. Canon PowerShot SD200 Battery Replacement, Battery: paso 1, imagen 1 de 3 Canon PowerShot SD200 Battery Replacement, Battery: paso 1, imagen 2 de 3 Canon PowerShot SD200 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • The camera used to create these repair guides had a broken lens assembly. As a result, the lens is sticking out in all of the photos, but it is important to note that this should not be the case with your camera. The lens should retract itself back into the camera when it is turned off.
    • Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • Both battery and memory card should now be visible.
  2. Canon PowerShot SD200 Battery Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD200 Battery Replacement: paso 2, imagen 2 de 2
    • Rotate the small brown tab towards the edge of the camera.
    • The battery should pop up.
  3. Canon PowerShot SD200 Battery Replacement: paso 3, imagen 1 de 1
    • Pull the battery straight out of the battery holder.
    • When putting the battery back in, make sure it is oriented the same as it was before.
Conclusión
James Loy
Miembro Desde 10/06/10
103 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-12, Maness Fall 2010 Miembro de Cal Poly, Team 5-12, Maness Fall 2010
CPSU-MANESS-F10S5G12
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 3,037
