Saltar al contenido principal
Nintendo 2DS Motherboard Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Paso 3
Nintendo 2DS Motherboard Replacement, Remove Top Panel: paso 0, imagen 1 de 3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: paso 0, imagen 2 de 3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: paso 0, imagen 3 de 3
Remove Top Panel
  • The top panel can only be removed when the mother board is not secured.
  • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
  • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
  • Hold the top panel with your fingers and pull away from the device to remove it.
  • The top panel should come off easily, with very little force applied.
Insertar traducción aquí
