Saltar al contenido principal
Toshiba Satellite 2435-S255 Monitor Replacement
Inglés
Holandés
Paso 4
Toshiba Satellite 2435-S255 Monitor Replacement, Detach the Hinges: paso 0, imagen 1 de 1
Detach the Hinges
  • To disconnect the monitor itself from the bottom part of the laptop, remove the two indicated 8mm screws (on the sides of the hinges).
  • Note for reassembly: make sure to screw in the monitor to the outer two holes, then use the inner holes for the casing.
Insertar traducción aquí
