Saltar al contenido principal
Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 0, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 0, imagen 2 de 2
  • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
  • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
  • When looking at the back of the camera, these two screws are on the right panel of the camera.
Insertar traducción aquí
