Saltar al contenido principal
MacBook Core Duo Upper Case Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 36 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 8
Paso 8
MacBook Core Duo Upper Case Replacement: paso 0, imagen 1 de 1
  • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
  • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
  • Do not pry from the bottom or the top, but from the sides.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
Insertar traducción aquí
